strange a/c headlight problem 01 Sebring convert
Old 07-23-2016, 09:15 PM
george3405's Avatar
Default strange a/c headlight problem 01 Sebring convert
My 2001 Sebring LX convertible a/c works fine normally. However, whenever the headlights are turned on air only comes out the defrost vent, no matter what setting it is on. Also the rear window defogger does not come on with the headlights on, but with lights off it works fine. Any ideas? I thought maybe the alternator might be getting weak, but car starts fine and everything else seems okay. Thank you, George
Old 07-24-2016, 10:19 AM
jopizz's Avatar
I would definitely put a voltmeter on your battery and see what kind of voltage drop you are getting with the headlights on. Your alternator may be just strong enough to keep the battery charged but not strong enough to run multiple accessories.
John
Old 07-24-2016, 12:12 PM
Also, your control head on the A/C is failing. It's pretty common. Search through the forum here for many discussions of the issue and how to remedy it.
Old 07-24-2016, 09:06 PM
george3405's Avatar
DCotter you were right. I changed out the control head and that fixed it. Thanks to you all for your input and suggestions. George
Melssj5
04-24-2012 11:47 AM
Jches001
01-02-2011 02:55 PM
taz
12-15-2010 09:42 AM
Eric334
08-21-2009 10:23 PM
Ram
10-28-2008 11:55 AM
Quick Reply: strange a/c headlight problem 01 Sebring convert
