Taller tires on my 2010 Sebring 2.4
Old 02-23-2011, 08:33 AM
sodakmopar's Avatar
Default Taller tires on my 2010 Sebring 2.4
Can I run taller tires on my 2010 Sebring 2.4 without any negative consequences? I want to fill out the wheel well a little better. I've done it will my mopar truck and suv with no ill effects. I was also able to reprogram the PCM so that the speedo was still reading correct. Are you able to reprogram the sebring PCM to reflect a change in tire size? Is it possible to find a site showing what oversized tires will fit and what won't? Will it damage my transmission or anything by running larger than stock tires? Thanks!
Old 02-27-2011, 09:24 PM
sodakmopar's Avatar
mopar
Old 08-10-2011, 12:55 AM
sodakmopar's Avatar
bump!!!!!
Old 08-10-2011, 09:07 AM
I see you have gotten no response in six months on your question. I don't know about your 2010, but on my 2001, there was very little clearance in the wheel wells. The idiot who owned the car before me tried to use SAE tools on metric bolts, and wound up leaving a 1/2 inch socket stuck to the head of a 13mm bolt that held the battery in place. That socket lifted the battery cover a little toward the tire when he put it back together, and as a result, the tire wore a hole through the battery cover.
I would suspect that there probably isn't a great deal of difference in the case of the 2010.
Old 08-10-2011, 05:49 PM
sodakmopar's Avatar
thanks for the reply. I will just have to put one tire on a ramp for articulation and do some measuring.
Old 08-20-2011, 11:31 PM
helo735's Avatar
why not just lower it?
Old 08-21-2011, 10:19 AM
sodakmopar's Avatar
Then I will have clearance issues and a broken front bumper.
Old 08-24-2011, 09:40 PM
Bib's Avatar
Bib
Bib is offline
go to miata.com, there should be no problems.
kzee
09-18-2014 09:24 PM
cowoygunner14
02-27-2014 11:30 AM
adam.davis
12-30-2010 06:48 PM
redleopardette
02-14-2006 04:42 PM
redleopardette
02-10-2006 06:46 PM
Quick Reply: Taller tires on my 2010 Sebring 2.4
