2004 300m having problems adding water
I repair my Chrysler 300M I got the heads done, new head gaskets, timing belt water pumps tensioner new injectors
everything is new, engine started immediately and runs great but I can't go far because I'm having a problem adding coolant to the car, I purchase 2 gallons from the dealer and only a 1/4 when in, the small yellow/ white plastic bottle is full but I know the radiator is empty. ( new thermostat )
Help why I can't add any coolant, I also try water.
Hoses have a lining that can become detached and block circulation. Check your hoses. BTW, the bottom hose should be much cooler than the top hose. The coolant comes out of the radiator at the bottom after it has been cooled.
Revots12
06-27-2011 09:48 PM
littlemimus
10-17-2009 02:47 PM
donnyohs
22
07-17-2009 03:19 PM
woodlin321
10-08-2008 09:43 PM
