Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler 300, 300C & 300C SRT-8
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 04-20-2011, 05:03 PM
Unhappy Nasty coolant leak in my 300m
My first post. I usually find all my answers by searching these forums but not this time. Hope you can help.
I've owned my '99 300m since new and have always maintained it myself to the highest degree. A steady coolant leak developed yesterday and it's coming out of the bottom directly between where the engine bolts to the transaxle - right through the bolt-on piece that the manual calls the case stiffener (it structurally helps tie the engine to the transaxle). It's as if a core plug let go behind the flexplate, but I don't think there is a core plug back there - or is there? I took everything off the top side (cowl cover, strut tower support, etc) to get a good look at all the heater and coolant tank hoses, as well as the rear core plugs in the heads - everything is perfectly dry up top and no sign of coolant running down the sides of the engine - only directly at the back of the engine.
The car has only 64,000 miles on it and I've replaced the coolant every year with Zerex G-05 & distilled water.
Are there any known issues Chrysler has had about something like this. If the engine needs to come out, that's a bigger job than I want to tackle. Is a project like this better left to the dealer or can a competent independant shop be expected to do it right?
Thanks for any suggestions
Don.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 04-20-2011, 05:21 PM
Oops, I got the case stiffener part wrong - it's called a structural coller and it bolts directly to the bottom rear of the oil pan and to the bell housing. The coolant is leaking directly through and around this piece.
Old 04-20-2011, 06:07 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
I suggest u take it to a shop let them pressure test the system and see where the leak is really coming from because there is no coolant going into or around the trans
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 04-20-2011, 06:32 PM
Agreed,
Just for giggles, Humor me...
Pull the transmission dipstick, and make sure the trans hasnt been filled with coolant. I recently saw a Radiator go defective, where the transcooler ruptured, and the coolant was pumped int the trans, overfilled, and spit out the vent.....Surprising enough, The stuff that hit the ground was PURE COOLANT and NOT the Milkshake Slush I would have expected to see.
__________________
Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Old 04-25-2011, 02:52 PM
I tracked it down to a water pump leak. Turns out the coolant leak follows the pan rails to the back of the motor and dribbles down from there. Also doing the timing belt, idlers, hoses and thermostat while I'm in there. What a pain to get at the thermostat - any hints to make it easier to get to? I got a few days before the parts get here from Rock Auto.
Don
Old 04-27-2011, 08:34 AM
TNtech's Avatar
Don
Take off the power steering pump and lay it out of the way. You have a straight shot at it from the top. You'll need a wobble socket or a gear wrench...Sears has them.
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
Tags
1999, 300, 300m, 99, add, antifreeze, chrysler, coolant, crysler, leak, pressure, put, radiator, steady, tank
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
