2008 5.7 Aspen thoughts?
Old 10-20-2014, 08:52 AM
ChryslerCares's Avatar
Dancamelonat,
In the U.S. the muffler is covered under the 3 year or 36K mile basic warranty. The catalytic converter is covered for 8 yrs. or 80K miles in the U.S. I'm not sure about Canadian warranties. I would suggest contacting Chrysler Canada for that info as they "technically" are a separate company with their own warranties.
Regarding the build sheet you have requested, its listed below:
VIN 1A8HW58228F112837
Vehicle Description CHRYSLER ASPEN LIMITED 4X4
Model Year 2008
Body Model HG 5 P 74
Color PWG- Cool Vanilla Clear Coat
Sales Code --- Description
*DZ Leather Trimmed 1st & 2nd Row Seats
-J1 Light Graystone
ADJP Heavy Duty Service Group
ADLP Skid Plate Group
AFHS Interior Convenience Group
AHC Trailer Tow Group
AJPS Power Convenience Group
ALW Popular Equipment Group II
APAS Monotone Paint
AWRS Ambient Light Group
BABS 160 Amp Alternator
BCQS 750 Amp Maintenance Free Battery
BCSS Battery Run Down Protection
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CACP Low Back Bucket Seats
CBZS Prem Vinyl Door Trim w/Map Pocket
CFGS 3rd Row 3-Pass 60/40 Split Seat
CGL 2nd Row 40/20/40 Reclining Seat
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags
CJ5P Supp. Side Curtain All Rows Air Bags
CKAS Carpets - Floor and Cargo Area
CKTS Cargo Tie Down Loops
CLXP Luxury Front & Rear Floor Mats
CSRS Passenger Assist Handles
CUNS Overhead Console
CURS Rear Compartment Storage Tray
CVMS Full Length Flr Console Prem A/Rest
DGQ 5-Spd Automatic 545RFE Transmission
DHUS Elec Shift-on-the-Fly,F/Time T/Case
DJDS 205MM Front Axle
DMHP 3.92 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
EZB 5.7L V8 HEMI MDS Engine
GARP Laminated Front and Rear Door Glass
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFAS Rear Window Defroster
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNZP Auto Dim Exterior Driver Mirror
GWAS Power Sunroof
GXRS Keyless Entry
GXXP Sentry Key Theft Deterrent System
GYEP Power 6X9 Multi-Func F/Away Mirrors
HAFP Air Cond ATC w/Dual Zone Control
HBBS Rear Air Conditioning w/Heater
JAMS Soft Touch Instr. Panel w/Woodgrain
JA2S Instrument Cluster w/Tach
JBGS Instrument Panel Woodgrain Bezel
JDCS 200 KPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHDS Rear Var Intermittent Wiper/Washer
JJBS Dual Note Electric Horns
JJJS 12V Power Outlet Mounted in IP
JJMS Auxiliary 12-Volt Rear Power Outlet
JKPP 12V Auxiliary Power Outlet
JKVS 115V Auxiliary Power Outlet
JNBP Instr Pnl w/Ambient Lighting Bezel
JPBS Power Locks
JPKP Pwr 8-Way Drvr Mem 4-Way Pass Seats
JPMP Heated Front Seats
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRCP Power Liftgate
LABS Tire Pressure Monitoring Warning LP
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LANS Decklid/Liftgate Ajar Warning Lamp
LAXS Front Passenger Seat Belt Alert
LAZP Vehicle Information Center
LBPP Liftgate LED Lamps
LBRS Front & Rear Aimable LED Lamps
LCEP Rear Courtesy/Reading Lamps
LEMP Exterior Mirrors w/Memory
LEZP Radio/Drvr Seat/Mirrors/HVAC Memory
LMGP Automatic Headlamps
LMKS Daytime Running Headlamps, High Beam
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MCXS Body Color Fascias w/Bright Insert
MDAS Front License Plate Bracket
MFMS Black/Bright Grille
MHAS Black Windshield Moldings
MJBS Chrome Bodyside Molding
MMSS Bright Belt Moldings
MNCS Bright Door Handles
MNPS Bright License Plate Brow
MRLP Body Color Running Boards
MVAS Limited Badge
MV9S Pro 4X Decal
MWHS Rear Wheelhouse Liners
MWPS Body Color/Bright Side Roof Rails
MW5P Hemi Badge
MYRS Aspen Badge
NAA Federal Emissions
NFJS 27 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHJP Exterior Mirrors w/Heating Element
NHKS Engine Block Heater
NHMS Speed Control
NHNS Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDS Next Generation Engine Controller
PWG Cool Vanilla Clear Coat
RDDS Fixed Long Mast Antenna
RDZS Steering Wheel Mounted Audio Ctrls
RD6P 368 Watt Amplifier
RER Uconnect 730N CD/DVD/MP3/HDD/NAV
RGDP 8 Alpine Speakers W/Subwoofer
RSCS SIRIUS Satellite Radio
RSPP Uconnect Voice Command w/Bluetooth
SBAS Power Rack and Pinion Steering
SCKS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHCS Front and Rear Stabilizer Bars
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TVCP P265/50R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WF1P 17" Steel Spare Wheel
WPGP 20X8.0 Aluminum Chrome Clad Wheels
XAAP ParkSense Rear Park Assist System
XACP ParkView(TM) Rear Back-up Camera
XAMP Power Adjustable Pedals w/Memory
XBMP Remote Start System
XBNS Tip Start
XDXS Scissor Type Jack
XEAP Tow Hooks
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XFHP Class IV Receiver Hitch
XF2P 7 and 4 Pin Wiring Harness
XGDP Universal Garage Door Opener
XGMP Tire Pressure Monitoring Display
XGQS Synthetic Rear Axle Lube
XJCP Locking Lug Nuts
XLRP French/Canadian Language
XRVP Rear Seat Video System
XSLS Brake/Park Interlock
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
X9AP For More Info, Call 888-539-7474
X97P 1-Year Service Provided by SIRIUS
YACS Build To Canada Mkt. Specifications
ZAAP Spring - Left Front
ZASP Spring - Left Rear
ZNAP Spring - Right Front
ZNSP Spring - Right Rear
Z5EP GVW Rating - 6650#
1ABS Canada Dealer Retail
5I4S Four Wheel Drive (4WD)/(4X4)
5RES 2008 Vehicle Specifications
51HS HG-Vehicle Family
  #32
Old 10-22-2014, 11:07 AM
Dancamelonat's Avatar
Thanks CC, I bought the truck that was well maintained, clean as new. Very happy !
The owner mentionned that sometimes the engine light comes on and the dealer mentionned that it's a pressure leak from the gaz tank. It can come from anywhere in the lines.... Beside checking the gaz cap, is there a weak place that I should look. Owner told me to disconnect battery to clear the engine light. ( good or not ? )
Thanks.
  #33
Old 10-23-2014, 09:59 AM
blake.fowkes's Avatar
Mine was doing this recently as well. Make sure that you clean the filler neck where it meets the gas cap. Mine did not look all that bad but I cleaned it up really well and have not had that issue since.
  #34
Old 12-08-2014, 09:36 AM
keda's Avatar
Hello guys and gals, I just purchased a great condition 2008 chrysler aspen limited 4wd j with 120000...would like a build sheet if anyone can help me out. Much appreciation.
  #35
Old 12-08-2014, 10:57 AM
Keda,
You will need to provide the last eight characters of your VIN Number in order to determine the build sheet data for your specific vehicle.
  #36
Old 12-08-2014, 11:15 AM
keda's Avatar
8F136730... thanks
  #37
Old 12-08-2014, 07:01 PM
keda's Avatar
C.C. I need you bud... waiting for that build sheet. ..
  #38
Old 12-08-2014, 09:26 PM
keda's Avatar
hey there, just need a build sheet when you get the time... 8F136730
  #39
Old 12-10-2014, 01:52 PM
I'm sorry Keda,
I've been busy and haven't had time to play on the forum. Here you go....
According to our records, your vehicle was equipped from the factory with the following:
VIN 1A8HW58258F136730
Model Year 2008
-J1 Light Graystone
APAS Monotone Paint
CGLS 2nd Row 40/20/40 Reclining Seat
DHUP Elec Shift-on-the-Fly,F/Time T/Case
GWA Power Sunroof
GXRS Keyless Entry
GXXS Sentry Key Theft Deterrent System
JCBS 120 MPH Primary Speedometer
JPBS Power Locks
JRCP Power Liftgate
LMBS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAS Security Alarm
MVAS Limited Badge
MV9S Pro 4X Decal
MW5P Hemi Badge
MYRS Aspen Badge
NHMS Speed Control
PKG Light Sandstone Met. Clear Coat
QKGS Light Sandstone Met. Clear Coat
XBNS Tip Start
XEAP Tow Hooks
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
Z5ES GVW Rating - 6650#
2TJA Customer Preferred Package 2TJ
28J Customer Preferred Package 28J
  #40
Old 01-23-2017, 12:59 PM
hotcharity95's Avatar
Wondering if I could get some info on my vehicle that I've had for 6 years and going strong:
1A8HW58208F147103
THANKS!
Quick Reply: 2008 5.7 Aspen thoughts?
