Automatic Transmission Fluid Level
Hi,
I have a problem with the transmission oil level. Regardless of temperature of the engine or the ambient, oil is always at the same level between HOT and COLD holes. In the garage I have a temperature of about 20°C (68°F), the car is from 2 days not ridden and oil is at the same level as in the picture.
Should I drain the oil, (once I did it, because when the engine was cold, oil was above HOT hole) ?
I think the previous owner had to pour the oil.
Is the fluid level will be too low, the EVIC will show me some message or warning light about transmissions fluid level?
Thanks.
Thanks.
Nuieve
10-29-2013 04:37 AM
alexnz
05-16-2012 02:00 PM
