Originally Posted by kevcot
Recently both steering rack and tie rods were replaced on my 07 Aspen Limited AWD (5.7 Hemi) with 35k. Everything works fine ( no warning lights on) at startup until I turn the steering wheel in any direction then ESP/BAS warning lights come on. When I start it up again the ESP/BAS light stays off until I turn the steering wheel slightly then they come on. The mechanic said over time these lights will "learn " to go off at startup. Really? It sounds to me like a sensor's triggering something. Anybody else experienced this problem?
Is your steering wheel off-center? If it's coming on every time I bet the alignment's off. The steering angle sensor should only have to be initialized once, which is what you're doing when you do the steering wheel dance. It will need it again if a module is reset or the battery is disconnected.
