EVAP codes...
If the problem dont be solved by replacing the esim then its maybe the purge solenoid. If you replace it, i would NOT take the dorman one (911-236). The dorman has one the side the wrong diameter outlet, its 1.6mm more than oem. Not the same like oem 4891739AA. The purge solenoid from airtex has also the same diamter like oem.
