04 pac
Don't forget you will have to have Chrysler flash it. Also, if you get it from chrysler, get some paint because my PCM came bare as they sandblasted the cover and DID NOT PAINT IT. Still can't believe it. I asked the parts guy and he said this was "normal" Also, check the plugs (where they actual connect and the rear of the connector) for corrosion. Ours had a couple that had bad connections so I redid 2 of the 4 plugs. I also had to make a new plate because the computer was corroded to the mounting plate.
I orderd mine fron there( ACR Auto Computers LIFETIME WARRANTY! they program it and it should be good to go like it is .
Got my pcm yesterday, plug it in and it started right away,and it is running very good when it doe;s run. I put a new timing belt and water pump (may as well). out of nowhere it would stop and not restart for about 10 min.I got a code p0480 to fix still, and I replaced the asd relay code p0688. Will see what else come up.
Well today I fix code P0480, I had to replace the radiator fan relay brown and mauve wire, from the gray connector behind the dr side headlight to the pcm, now cooling fan are working good, no more engine light on.
Now I got a knock under the dash when taking off(suspect a motor mount) and a wheel sensor.
PS. Took it for a drive today about 60 kms no problem at all.
aschabel
08-28-2010 12:18 PM
