Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Pacifica
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 05-12-2011, 06:51 PM
Default 2004 Pacifica Issue, Please help me!!!
Hello All,
I am new to this forum so please take it easy on me if I sound stupid on this post. I am having some problems on my 04 Pacifica. It as a vacuum leak that you can actually hear when you open the hood. I tracked it down by listening and feeling around. I figured it out to be around a part that I am not 100 % what it is. I was needing help to figure out what it is. That way I know what I would be getting myself into if I go to fix it myself. Anyway, it is a square part that has a straight piece (Black Plastic) that runs up under the plastic towards top, right side of the motor, if you are looking at it from the front of the vehicle. It is located on the back, right side of the motor, more towards the top. I found that the piece that runs under the plastic actually moves back and forth on like a pivot on the side of the square part that I am trying to figure out. I traced the vacuum leak to the other end of the rod or plastic shaft that runs up under the plastic on top of the motor. I have not actually taken all the plastic off the top of the motor to see if I can get to this end that is leaking. I just felt around it and you can hear the vacuum leak change sounds. Also, when you rotate the plastic piece back and forth it changes how it idles. If you move it in one direction it also makes like a clanking sounds. This vacuum leak makes the idle sporadic when just siting and idling. It also can get so bad it makes the motor die. It used to do it just every now and then, but recently it is all the time. If someone could please help me. I am sorry for the long post and sorry if it sounds confusing but I am really lost on this. Thanks for any help I may get.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 05-12-2011, 08:59 PM
Damn Newbies....
Anyway......Welcome, and the only stupid question is the one that you didnt ask.
What you are describing is a "Runner Valve"...Which Engine are we discussing ????
Before you plunk down your hard earned cash....Take apart what needs to be removed to VERIFY where the leak is. That is probably it, But there are other things in the area that can leak. PLENUMS are PLASTIC, and can break just as easily as anything else , so Make sure of what youre replacing and why.... Ive seen my fair share of leaking "PIVOT BUSHINGS" which require the plenum to be replaced.....So get it right ...this stuff aint cheap enough to go guessing.
__________________
Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Old 05-12-2011, 09:05 PM
Default 3.5l
Hello Thanks,
It has a 3.5L in it. Does this sound like something that would leak or is common to leak on this model? If so you think it would be hard to change out myself and what does something like this usually cost? Sorry for so many questions! I really do appreciate all the help you can give!
Old 05-12-2011, 09:14 PM
Also, what part am I looking for exactly if I am having to replace this, runner valve? I will take the plastic apart and get down to it to confirm it, but I am 99% sure this is what is causing all the problems.
Old 05-12-2011, 09:20 PM
Yes, absolutely....But as I said, there are other things there that can leak as well.
Now, There appears to be 2 of them, One is a Manifold Tuning Valve, the other is a short runner valve.... Best guess, they would both be in the neighborhood of 165$ each.
__________________
Old 05-12-2011, 09:33 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
"Anyway......Welcome, and the only stupid question is the one that you didnt ask."
not true how about this one?
QUESTION: I bought an a/c switch off eBay. I have no idea where it goes. I am mechanically inclined. The nomenclature is: switch interrupter commutator. The part number is20925. It is manufactured by 4 seasons out of Lewisville, TX
I have no idea where this goes. The problem originally was the a/c is not kicking on. I hotwired the a/c to the battery and it worked fine. I assume the problem is in the harness somewhere. There are no codes that come up.
You can email me direct if you wish.
ANSWER: first of all what kinda car is this
second why did u buy something that u are simply guessing at and then dont even know where or what it is?
---------- FOLLOW-UP ----------
QUESTION: why do find it necessary to be a ****ing prick?
ANSWER: ask me another stupid question then U will see me bring a prick
hope U find what ever it is u are looking for
QUESTION: **** you. get the **** off the panel if you cannot be a professional. and learn the context of the english language.
Answer: what kinda name is MARVIN Marvin the martin
have fun my ac works good and yours?
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 05-12-2011, 09:41 PM
And of course you deleted it...... Damn.... Our Tax dollars hard at work......??? Why do we even have SCHOOLS????
The sad part is...He probably put a 3000 dollar boombox stereo in the car and forgot to plug the switch panel back in....Which raises the stupid question of how can you afford a 3000 dollar stereo , when you have no common sense, or ability to think...
Cmon KEVIN, get with the program.......Whats wrong with you.....???You can fix a 60,000 dollar automobile, but you cant Fix STUPID?????
Anyway.....
Is this what youre looking at????
Short runner Valve
If thats it...Then You need to look VERY carefully at the Pivot bushings on the plenum.......
__________________
Old 05-12-2011, 09:53 PM
Yes, That is exactly what I have been looking at....The leak is on the other end of the plastic piece that runs towards the front of the motor off the SRV....Where do you buy these parts from? I have been searching on the web and can't find them anywhere....You have been a huge help!!! Thanks Again
Old 05-12-2011, 09:54 PM
A wee bit of a Trick, that the Djinn will now impart to you.....
Grab a roll of duct tape, and an assistant who smokes. Remove the air cleaner lid and hose, and cover the throttle body throat with tape. Pick a Vacuum hose on the intake. and remove the "OTHER END"...(Brake Booster hose works well).
Now...blow smoke into the intake, and see where it comes out.....Where the smoke exits, is where the vacuum enters.
__________________
Old 05-12-2011, 09:56 PM
Quite possibly a complete plenum.....either way...DEALER ONLY...
__________________
Tags
04, 2004, black, chrysler, manifold, noise, pacifica, plastic, plentum, plenum, rear, rod, tuning, vacuum, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
