2005 Pacifica awd transfer case fluid change
Hi
I have a 2005 Pacifica awd and I would like to change transfer case fluid. Does anyone have any info as where they are located (description or picture)? where do I drain & fill the fluid? Thanks in advance!!
RE: 2005 Pacifica awd transfer case fluid change
STANDARD PROCEDURE - PTU FLUID DRAIN/FILL
[ol][*]Raise vehicle on hoist.[*]Remove PTU drain plug. Drain fluid into suitable container.[*]Install drain plug and torque to 35 NĀ·m (26 ft. lbs.).[*]Remove PTU fill plug.[*]Fill PTU with 1.0L (2.1 pts.) of MoparĀ® 75W-90 Gear and Axle Lubricant.[*]Install fill plug and torque to 35 NĀ·m (26 ft. lbs.).[*]Lower vehicle. [/ol]
yarikoptic
07-14-2013 11:16 PM
morevert
12-08-2006 08:51 PM
