Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Pacifica
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 05-04-2011, 12:15 AM
Default 2005 Pacifica engine miss
I have a 2005 Pacifica AWD 3.5 with an intermittent engine miss in the #4 cylinder with the check engine light on steady. It is worse when holding a steady speed and seems worse when it's cold or damp outside. I have replaced the spark plugs and the coil on the #4 cylinder but it made no difference. Had a scanner put on it and it still shows engine miss in #4 cylinder. Any ideas on what to check next? Thanks for any help.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 05-04-2011, 10:49 AM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
fuel injector issue or internal engine issue
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 05-04-2011, 11:00 AM
Fuel injector makes sense. As I said it comes and goes and happens mainly at a steady speed, not so much at idle or accelerating. Would a fuel problem still show up as a misfire code on scanner? Thanks
Old 05-04-2011, 02:31 PM
yes the scanner only reads sensors and relays the info to the pcm then the pcm lets it be shown on the scanner
__________________
KKeller608@aol.com
Tags
05, 2, 2005, check, chrysler, cold, cylinder, engine, light, location, miss, order, pacifica, pasifica, start
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
