2006 Pacifica whining noise after wheel bearing replacement
Old 02-11-2015, 03:13 PM
Daniel Craig's Avatar
Default 2006 Pacifica whining noise after wheel bearing replacement
Hello,
I have a 2006 Pacifica. I thought the wheel bearing was going out so I replaced it. However, after the replacement it is still making the same whining noise that it was making before. What could it be? HELP?!?!?!?!?!?!?!?
Old 02-12-2015, 12:52 AM
u are aware how hard it is for someone not there to tell u whats making a noise over the internet?
Old 03-29-2015, 10:40 PM
I do understand. So here is a video. https://www.youtube.com/watch?v=hRg_...ature=youtu.be
Old 03-30-2015, 10:21 AM
"I thought the wheel bearing was going out so I replaced it."
"the" wheel bearing? Does your Pacifica have only one wheel bearing?
A whine that increases with speed and does not exist at standstill could very well be a wheel bearing. It could also be a transmission/differential problem. It could be something rubbing on a tire.
You might want to have a friend lean out the windows as you drive to see if you can localize the noise to one side/ front or rear.
If you can drive by a wall or even a tall curb with the windows open you might be able to tell which side it's on.
Old 04-02-2015, 01:47 PM
I isolated the noise to the driver side. Which is why I replaced that wheel bearing.
Old 04-02-2015, 02:44 PM
ChryslerCACares's Avatar
Daniel Craig,
Was the noise issue resolved with the bearing replacement?
Old 04-02-2015, 08:07 PM
There's a wheel bearing at the rear wheel also. But you knew that.
lastxit
08-22-2016 09:47 PM
Bojib
04-11-2015 11:28 AM
travelmad
08-28-2013 04:36 PM
SadSack
Cirrus & Breeze
02-23-2013 06:46 AM
gdavis
03-26-2011 01:01 PM
Quick Reply: 2006 Pacifica whining noise after wheel bearing replacement
