2007 Pacifica ball joint replacement problem
Old 10-23-2015, 04:28 PM
ssdavies1's Avatar
Unhappy 2007 Pacifica ball joint replacement problem
Sure hope someone can help me with this. I went to replace the right front lower ball joint, and when the control arm came loose, there was a very loud bang that seemed to come from the transmission/frame area. After replacing the ball joint, I was unable to get the stud and control arm hole to line up, so I disconnected the strut to try and move the spindle around. No luck (with the ball joint bolted up, the top strut mount bolt on the spindle won't line up), and now it appears the wheels are no longer aligned. What did I screw up? Did I mess up the strut (it's brand new). I'm now wondering if the issue is the entire control arm needs to be replaced, but that doesn't seem to explain why i can't get everything back together. How screwed am I?
Old 10-24-2015, 09:07 PM
ssdavies1's Avatar
I figured it out. There was a problem with the axle shaft. Got everything back together, need to replace the shaft...
Old 10-25-2015, 01:08 PM
busboy4's Avatar
Glad you found it.
Old 10-26-2015, 02:52 PM
ChryslerCares's Avatar
Glad to hear you solved the mystery! Keep us posted on the final result after you replace the shaft.
Panthersfan
08-19-2019 06:21 PM
Mcex
09-24-2014 11:44 AM
jimmy154
08-23-2011 05:59 PM
Blodgie1985
03-21-2010 01:10 PM
bjkroll
03-09-2010 08:41 AM
Quick Reply: 2007 Pacifica ball joint replacement problem
