Now THIS is a dirty cabin air filter
I'm in the process of doing some routine maintenance on my newly acquired '04 Pac, and thought to myself "I wonder if the cabin air filter has been changed recently....?"
I pulled the cover off, and as I was pulling the filter down, oak leaves cascaded down onto the carpet. Not sure if this is the original cabin air filter, but it might be!
Best $19 I spent today!
My guess is condensation (humidity from the A/C condenser) but not really sure.. You should check (I don't how to call it), but it's where the wipers are at.. Yours doesn't get wet on the driver side? If not, good, but if it ever does, check in there.. I don't why, but in there the seals or seems are not well sealed some times... In mine they weren't, and when it rained some water drained to the driver side floor mat..After that something went wrong in the car's electronics.. You can also get water from the sun roof if you have it.. It will come down the drivers side post, from right inside the plastic, water will be coming right out of the area where the plastic cover is bolted, usually that's a clogged drain ..So keep an eye out for that..
Thank you for the heads-up on these issues. I have a sunroof, but no leaking yet. I also haven't had any water on the driver's side floor mat, but I will keep an eye out for it. The car is garaged a lot, but occasionally makes it out into the rain.
Cabin Filter Replacement: 2004-2008 Chrysler Pacifica - 2005 Chrysler Pacifica Touring 3.5L V6
