Adding HID Headlights
Has anyone added factory HID headlights to a Pacifica? Are all the wiring harnesses already there? What parts are required besides the Bulbs and headlamp assemblies? What approximate costs are invlolved? Thanks in advance.
Rick
Rick
RE: Adding HID Headlights
From what I recall from reading you will need a main module which is very expensive. I believe you can get it to work by adding a harness which connects up to your existing bulb socket. Pretty much it enables you to bypass the module. You will need a specific harness for your current bulb type which I believe is H7. I was able to buy this harness on line and it was very reasonable. Good luck!
I installed Pilot HID www.pilothid.com They come with the wiring and ballast as needed when you place your order. Work great.
05-12-2006 02:05 PM
