04 Pacifica
When my mechanic was removing the cover for my air filter (not cabin, the one under hood) the case cracked and broke around the bolt in the front right. Now there is a square hole there, and I need to replace it. Can't find online where I can get this part from. Any help would be appreciated.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep KKeller608@aol.com http://kevinsmobilerepair.com
Try the web site www.car-parts.com, I've always had pretty good luck finding what I need there. Let's you filter to closest place, real handy. Just don't filter too close, part might be just across state line, somewhere you might be going anyway. Good Luck.
I've got the exact same problem. I put a fender washer over the screw so it still clamps down tight. The cheapest one I've seen on eBay so far is $80. The closest late model salvage yards I've found are 45-60 minute drives. If you find a cheap source online please post here and I'll get one too!
Did you check out the link from sembler3 ... Car-Part.com--Used Auto Parts Market I haven't ordered one yet, but looks like the best place, lots of choices. I have to wait until I fix some other things first, my p0499 issue an breaking cv axle... Probably an alternator, then I can get to the housing unless I find its causing a problem LOL.....
I saw that link but haven't looked for one. Another site I've used is Used Auto Parts | Junk Yards | Junk Yard Dog®. Usually when you submit a parts request you'll have 10-20 responses. But like you I have worse problems to fix first. We just bought the Pacifica but I've cleaned it out, got some floor mats for it, replaced all of the motor mounts, new spark plugs, picking up an EGR valve today, and I also have a bad CV shaft. Once I'm done with all of that I'll think about the filter cover...although right now my fender washer is making it seal up fine.
