Blower motor problem
2004 Pacifica A/C Problem..Need to fix ASAP..Help
The Air Conditioning in my 2004 Pacifica is not working at all...I replaced the Resistor that located behind the glovebox and all the fuses and nothing works. When I turn on the A/C air does blow out the rear, but not cold or hot and when i put on the defrost air does come out very slowly...now If i turn on the A/C while im on the highway doing 60 MPH or more the air seeps through the front very slowly and faint....So I am not sure if its the front blower motor or what...May someone please suggest me to do something. I was planing to replace the blower motor and see if that works...any ideas?
hi soulpoehl. i think the 2004 pacifica has the automatic a/c so it has a power module instead of a resistor. its more expensive but u can change it yourself. u have to open the glovebox door then push on the sides of the door to clear the rubber bumpers. then let it hang down and the module is right there with 2 wire plugs connected to it. remove the plugs and unbolt the 2 bolts and it comes right out
I was also used 2004 pacifica. It had automatic a/c. It had gave such a nice cooling inside the car. I have noticed that When The tempreture very hot then It had automated increased it fan speed. So It was so wondering.
Vanman
15
07-17-2009 06:17 PM
