Check engine code p0420( catalyst efficiency low bank 1
Old 11-12-2010, 06:19 PM
green earth's Avatar
Default Check engine code p0420( catalyst efficiency low bank 1
I have a 05 Pac... Please give me some insight on P0420 code( autozone readout) per check engine light...details below per autozone printout
Definition
Catalyst efficiency low bank 1
Proable cause
1.. Catalytic converter defective( failure possibly due to #2,3, or 4)
2... Engine misfire or running condition
3... large vacuum leak
4... engine oil leakage into exhaust - valve guide seals, pistonrings
now since I haven't had a tune up since buying the Pac 2yrs ago( dashboard reads 75,000 mi) , if I where to replace the the spark plugs could that correct the issue?
any insight would be helpful
Old 11-12-2010, 08:18 PM
It might be a good idea to replace the plugs. Take a good look at the old ones as they come out. Look for indications of oil fouling (problem 4) or excessive heat damage (Problem 3). If such problems are found, you'll have to hunt down the cause(s).
Good luck.
Old 11-12-2010, 09:32 PM
thanks DCotter0579, also is there any good diagrams that show how to preform the tune up as I see there are many bolts / screws and plugs that appear that have to be removed
Old 11-13-2010, 12:06 AM
u have a bad converter a tune up wont fix anything plus they are 100k plugs
Old 02-23-2012, 02:00 AM
grbullets's Avatar
I agree, the plugs are good for 100K. It will not fix your issue. You need to have the emissions system looked at. O2 sensors, EGR,etc, but you likely have a cat converter going bad. They don't last forever.
Brandontw
08-20-2009 09:37 AM
vb4921
07-31-2009 09:58 PM
Sam99
07-06-2009 10:39 PM
vb4921
07-05-2009 09:57 PM
Evapa
10-23-2008 12:28 PM
Quick Reply: Check engine code p0420( catalyst efficiency low bank 1
