Cruise control fixed - vacuum line - Chrysler Forum - Chrysler Enthusiast Forums
Thread Tools Search this Thread
Old 09-13-2010, 02:10 PM
Default Cruise control fixed - vacuum line
In swapping out my EGR valve, and removing the battery box, I found the problem that fixed my cruise control. It was a small vacuum line from the bottom of the battery box to the (vacuum tank?) thing mounted above the right side of the radiator. The line was cracked and corroded. Previously the accel button on the steering wheel appeared to do nothing. Now it instantly pulls the pedal from my foot and takes over, holding cruise speed.
Old 09-13-2010, 08:08 PM
Hi,
I am having trouble with my cruise control also. So did you to replace that vacuum line? What was the part number or the name of that line?
Thanks.
Old 09-14-2010, 11:06 AM
I was able to cut off the corroded area, removed the remaining tube from the battery box side "L" connector, and inserted the rest of the good hose into the battery box "L" connector. Then reconnected to the battery box. There isn't any slack, but it reached fine.
Old 09-14-2010, 09:38 PM
TNtech's Avatar
There are no PNs for vacuum hose. Just cut off a small piece and take it into a parts store. Now, EVAP Emissions hoses are a different story sometimes
Old 09-15-2010, 08:16 PM
Ok, I will give it a shot. Thanks for helpful replies.
Old 06-02-2011, 02:34 AM
Default It was vacuum canister instead of hose.......
Alright so I tinkered with the vacuum hose and could not find any problem with the hose. So I mentioned it to the mechanic on my last visit. It turned out that there was some problem with the 'vacuum canister'. After replacing the vacuum canister, cruise control is working just fine now.
This info may help someone.
Thread Thread Starter Forum Replies Last Post
Need to find where a vacuum line goes??? mikemonce Chrysler 200 & Sebring 2 09-20-2013 03:18 PM
"CRUISE" lights up for only one second before it goes out- cruise not working carsoftampabay Cirrus & Breeze 1 10-27-2012 12:31 AM
vacuum line from brake booster muse6638 Chrysler Pacifica 0 03-26-2012 05:41 PM
Sebring vacuum line Sebring 01 Chrysler 200 & Sebring 0 03-22-2012 04:16 PM
2002 concorde Missing a vacuum line? W/Pic imfocused 300M, Concorde, LHS, New Yorker 5 05-10-2010 05:54 PM
Tags
300, 98, chrysler, control, convertible, crossfire, cruise, forum, hose, line, lines, pacifica, sebring, tank, vacuum
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
