3rd led brake lamp not working
Old 02-09-2011, 09:01 AM
gbeach's Avatar
Default 3rd led brake lamp not working
brake lamp on liftgate not working on my 06 pacifica. I did see them flicker. any ideas.
Old 02-09-2011, 09:20 AM
United1's Avatar
Silly question, but you did not say you did, so hear goes. Did you check the bulb? I suspect a bad filament or dirty contacts.
Old 02-09-2011, 11:27 AM
gbeach's Avatar
they are leds, so there is more than one. it looks like a assy.
Old 02-09-2011, 03:12 PM
Djinn-n-Tonic's Avatar
Feeling Brave?????
Yes its an assembly...... Moisture collects in the housing and rots the "LEGS" of the led's, and The circuit board gets "Green + Fuzzy"....
If your good with a soldering Iron and a Pencil eraser...It is USUALLY fixable, But tedious and time consuming.....Your other option is to replace the lamp assy.
Old 02-10-2011, 01:21 PM
gbeach's Avatar
I use a soldering iron everyday, so I am good with that. but can I get to the assy to do the soldering or is it enclosed.
thanks for the info
4everrunning
06-04-2019 11:30 AM
Bazer79
20
01-25-2014 04:30 AM
Philkaye
06-27-2010 05:59 PM
HarleyWeewax
10-13-2009 06:51 AM
Quick Reply: 3rd led brake lamp not working
