Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Pacifica
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-12-2011, 09:05 PM
Default Help! No speedo, tach, temp, or gas gauges!
I have a 2007 pacifica 4.0 awd. i don't have the fancy cluster with the nav or backup camera. my car sat for a few days and i started it up to find that the speedo, tach,temp and gas gauges don't work. all the lights come on on the cluster except the message box in the lower left corner. the mileage and gear selection box is light up fine. i tried disconnecting the battery and that didn't help. Is my cluster dead or is there other problems going on?
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 09-12-2011, 09:06 PM
btw....the car starts and runs fine.
Old 09-15-2011, 08:12 AM
dormant75,
I checked TSB's for the 2007 model year Pacifica and do not see any that related to concern described in your post. On the surface it does sound like a failed instrument cluster.
The Instrument Cluster (IC) is located in the instrument panel and provides the driver with vehicle speed (speedometer), engine speed (tachometer), fuel level (fuel gauge), engine temperature (temperature gauge), gear position (PRND8), odometer and two trip odometers with MPH or Km/h unit displayed and compass mini trip information. The instrument cluster displays various status and warning messages using a re-configurable Vacuum Fluorescent (VF) display. Fixed ISO indicators and the fixed VF displays provide the following status and warning indicators using hard indicators:
  • Low Fuel
  • High Engine Temperature
  • Right and Left Turn Signals
  • ABS
  • Traction Control or Acceleration Skid Control (ASR)
  • Brake
  • Seat Belt
  • Airbag
  • Battery Charging Failure
  • High Beam
  • Oil Pressure
  • Malfunction Indicator Lamp (MIL)
  • Front Fog lamps
  • Cruise Set (Right VF Display)
  • Overdrive Off (Right VF Display)
  • AutoStick (Right VF Display)
  • Tire Pressure Monitoring
  • EVIC Display (Left VF Display)
  • Electronic Stability Program (ESP)/Brake Assist System (BAS) - (if equipped)
  • Electronic Throttle Control (ETC)
  • All-Wheel Drive (AWD!) - (if AWD equipped)
The cluster Thin Filmed Transistor (TFT) screen (if so equipped) shall have the capability to display vehicle navigation information (such as maps and turn-by-turn direction) as input by the navigation module.
With all that said I would certainly recommend getting a professional diagnosis from your local dealer before spending money on a new cluster just in case its something as simple.
Tags
2000, 300m, chrysler, dont, fancy, gas, gass, gauge, gauges, pacifica, speedometer, speedometertach, tach, tachometer, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
