HID Installation Problem, HELP!
Hey Pacificers lol
I installed HID's on my Pacifica 05 and the driver side is not turning on now... Its not the bulb! Im trying to figure out if i need to hook it up a different way or what. We tried to find the headlight fuse but nothing.
I need to know what i need to do or if i need to install it differently. It did work for a couple of months... Help! chrysler chargin 90$ "JUST" 2 find out what it is! wow.....
The HID's are installed the regular way. The only thing i can say is that the light use 2 stay on after i turned of the car but it would go off after 2 minutes. I dont think its sopose 2 do that with this kind of pacifica...
this my truck here: http://www.cardomain.com/ride/3073250
How funny is that. I was just in the process of figuring out if there was a fuse for this very problem. I have an 06 Pac that I've had an hid kit in for 10 months. Right side headlight quit working. I tohught it was blown so I ordered 2 new ones. That didn't fix the problem. I also have 2 new control units so I switched them in and out and tried all 3 bulbs. Nothing worked. We are not getting power to our drivers side low beam head lamp. I too would like to know what the heck is causing this. Please keep me in the loop. If I can figure it out I'll post the cure.
Thanks,
Darrell
Thanks,
Darrell
I had the same problem on my 05. I narrowed it down to the light not getting enough power from that harness(mine was the driver side, getting 3-5volts only)and this was after I had them in for 7-8 months. What I did is used a relay wired to the battery and switched on by the pass. side headlight harness. I haven't had any problems since(1+yr.)
Hope that helps you guys any
Kevin
Kevin
I don't have the HID lights but have read alot about them. All the ones I read about mention the module that the lights connect to being different and needs to be changed also. If I can find the info I will post more, but if you only change the lights, they will work but with intermittent problems.
