Pacifica '04 Coolant Overheating/Front Fans not working
#21
Hello, similar issue with my 2008 pacifica. Both rad fans don't work and engine overheats. Supplied 12 volts directly to fans and they both run. Checked all possible fuses with multimeter and all fine. I replaced the relay riveted to the bumper but still neither fans spin when engine is hot and/or A/C turned on. Any help will be greatly appreciated. Thanks
#22
#25
Hope this helps.
#27
Same thing happening to my 2004 Pacifica AWD. Went to gas stn earlier and the heat wasn't blowing in front but was in rear.. Few hrs later got in the car to go to walmart and it overheated!! I'm freaking out. Need advise. Am a single mom on a very tight budget this is my daily driver and have only had for a month. I yi yi. Pls help. Matt.ashknippenberg @ y a h o o. Pls help me. The local service center wanted $100 just to diagnose problem!!! Omg. God bless.. Hope to get some real answers soon!
#28
This time of year the cooling fans won't come on much, if at all. They are not supposed to run all the time. They are controlled by the engine computer and only come on when certain conditions require that they come on. If the car is not overheating there probably is nothing wrong. If the car is overheating then the fans could be part of the problem.
#29
#30
I am new to this site but am familiar with controls of this type from owning/repairing vehicles produced by the ex-spouse of Chrysler. My brother-in-law's 2006 Pacifica recently had fan control failure while en route from Disneyworld back home to Maine. Fans wouldn't operate with AC turned on and coolant temp. at 230 and above. Old school mechanic diagnosed a bad relay, ordered one and plugged it in (trying to ground the new relay by touching it to the bumper support) but the fans still would not operate. So he got them on their way by completing the fan circuit on the connector that plugs into the fan relay. Since I assume that grounding may not be necessary (the riveted connection is for heat dissipation, not grounding, correct?) and the necessary conditions were met for fan operation, have you ever run across inoperable fans due to a defective PCM? Thanks for your help. Mark
