Pacifica : Floor Jack Location
hello everyone, new to this forum.
Got a used 2004 pacifica touring a few months back.
Need to do an oil change and replace front rotors.
Can someone kindly post a picture of the factory recommended floor jack points or what you have used.
Much appreciated.
Much appreciated.
I use ramps to do an oil or trans oil and filter change, very convenient. When I need to jack it up with a floor jack, I use a small piece of 2x4 (maybe 8 0r 10 inches) on the jack lift disc and position the 2x4 on the frame. This isn't the greatest position because it's a bit toward the rear (about where the front door hinges are) but it works. Just make sure to stay clear of the brake and fuel lines. In the rear, you can use a spot just below the shock absorber.
Osprey
06-29-2009 09:31 PM
