05 HID headlight swap
Old 01-07-2017, 08:24 PM
Tony DiDonato's Avatar
Default 05 HID headlight swap
I have been searching and found some info, but not much on swapping halogen headlights to HID's. Has anyone successfully swapped them? Do I need a headlight wiring harness from a donor vehicle? Any info on what needs to be changed for them to work properly would be appreciated.
Old 01-07-2017, 10:19 PM
cirrus98's Avatar
Don't waste your money. Do an HID conversion kit. Way better output and less expensive. Did so on mine. Would redo it any day of the week.
Old 01-08-2017, 09:28 AM
Should I convert to the projector lenses, I currently have the cheap reflector lenses.
Old 01-08-2017, 10:07 PM
cirrus98's Avatar
Keep the stock reflectors. Take a look at the pictures(when i installed them). 1st one is the stock bulbs. 2nd is the conversion kit, with stock assemblies.
Attached Thumbnails 05 HID headlight swap-dscf1345.jpg   05 HID headlight swap-dscf1346.jpg
thefabe1
02-23-2015 03:31 PM
gitchesum
08-04-2009 08:39 PM
sonic gihad
01-27-2009 08:29 AM
andbudzi
02-20-2008 04:07 PM
fdfever
04-23-2007 02:29 AM
Quick Reply: 05 HID headlight swap
