rear end is leaking
Old 01-21-2009, 07:09 PM
polcat1p's Avatar
Default rear end is leaking
my wife took the 04 pac to the quick lube today, and they told her the rear diff was driping. Is this hard to fix?
Also we have a clunk noise from the pass side when going over bumps. i hear the control arm busings fail, is this true? Is it hard to fix this problem?
its an 04 awd pack. with 50k
Old 01-21-2009, 07:45 PM
xfire04's Avatar
Default RE: rear end is leaking
is it the pinion seal leaking ? the control arms are a problem on the pacs you will need to replace the complete control arm unless you are real handy i would take it to a good repair shop there is a tsb on the front end on your car
Old 01-21-2009, 08:19 PM
polcat1p's Avatar
not sure on the rear, untill i take it to my work garage. Whats a tsb? Is it a recall? I didnt buy the car new.
thanks
Old 01-21-2009, 08:35 PM
xfire04's Avatar
a tsb is not a recall it is a service bulletin
Old 01-21-2009, 08:40 PM
xfire04's Avatar
this is for chrysler techs to look at
Old 01-22-2009, 07:39 AM
scottydl's Avatar
A TSB (Technical Service Bulletin) is one step short of a recall, meaning it is a manufacturer's acknowledgment of a known/common problem and it tells the mechanics the best way to fix it. But the consumer is fully responsible for payment, unlike a federally-issued recall that is covered by the manufacturer. Recalls are generally only for safety issues, like brakes/airbags/fuel system and stuff like that where there are documented cases of people being seriously injured or killed because of a manufacturer defect. Sad but true. You can always check for recalls of any year/make/model vehicle by going to NHTSA.gov and clicking on "Vehicles and Equipment" then follow the appropriate links.
Andrew Sheridan
07-10-2013 09:43 PM
jonny
03-10-2011 04:37 AM
tarheelzfan1
02-10-2011 08:57 PM
dubs0587
04-27-2010 02:35 PM
Quick Reply: rear end is leaking
