Rear end sagging -- huge negative camber
I have two '04 Pacificas -- one is AWD, one is FWD. Anyways, the AWD one has a lower sitting rear end and the associated huge negative camber. I've checked rear link bushings -- all appear to be OK, except for the spring links (control arms). I had to replace the spring links and at the same time replaced the rear springs hoping it would help with the ride height/negative camber -- no change.
I wonder if Nivomat shocks are bad -- I noticed that if the car is driven the camber gets slightly better/ride height improves vs. if it was sitting a while...
Any ideas? How would I check the rear Nivomats -- I'd hate to replace them if there is NOTHING wrong with them -- they are very expensive.
I have the same issue what did you end up doing to take care of the problem? I was wondering the same thing about the shocks since they have light duty springs and they are supposed to take up the rest. Any help would be great...
