Serpentine Belt/AC Compressor
Old 11-22-2016, 08:02 PM
cirrus98's Avatar
Default Serpentine Belt/AC Compressor
So the bearing on the AC compressor pulley is going. Its squeals like crazy. Given that winter is getting settled in here, i want to skip out on replacing the compressor right now. Has anyone ever bypassed the compressor(with a shorter belt) and if so, what belt did you use?
Old 11-23-2016, 04:14 PM
First, take a ribbon and some tape and make sure the new routing will work. Then measure the correct length of ribbon. Then get friendly with the guys at the local parts store and find a belt of the correct length. (Promise them you'll come back in the spring and buy the new clutch/compressor.) Bring your own measuring tape.
Come back and brag about your success.
Old 03-21-2017, 03:21 PM
cirrus98's Avatar
Well I finally got around to changing it. So i used DAYCO Part # 5060810 from my local part store. Belt is 81 Inches long( Stock belt is 97 Inches long). Works like a charm for now(only been on the car for an hour). Belt is nice & tight once the tension is reapplied.
mediclev
Cirrus & Breeze
11-16-2008 07:33 PM
Daryl Baines
11-06-2008 04:33 PM
Daryl Baines
10-22-2008 01:35 PM
robbiedog
09-04-2007 04:19 PM
donandsandra
07-07-2007 04:17 PM
Quick Reply: Serpentine Belt/AC Compressor
