Shock/Strut Replacement
I've got 95k on my 04 AWD Pac. The ride has become soft and the car floats around more than it used to. Does anyone have a recommendation for front and rear shock/strut brand?
Also, does anyone have instructions for replacing them? Will I need an alignment when I'm done? Any special tools required?
Thanks!!
Thanks!!
RE: Shock/Strut Replacement
Edevries,
Here is what I found.
Monroe had Sensa-Trac and Reflex models. Sensa-Trac being the premium choice.
Front struts part # 72130 at AutoPartsGiant.com = $85.26 ea.
Bearing Plate part # 905911
Rear struts specialty part# 40211 = $329.46 ea.
I am having mine done today. I am only doing the front because the rear seems solid. The front floats a little and I like a tighter feel. I noticed the softness in the front when I go over speed bumps. I will let you know how it goes.
edevries,
I had the dealer replace my front struts and while they where at it I had them do the outer tie rod ends as well.
It rides much better now. Know more floating when on the highway. But I would still prefer a little firmer ride.
Had the struts, tie rod ends and four wheel alignment done for just over $700. for all parts and labor. They even drove me home and picked me back up.
cgytc
06-04-2008 05:02 PM
