Torque specs
Old 10-14-2014, 09:27 PM
rrolleston's Avatar
Default Torque specs
I changed a front wheel bearing hub. And was wondering what the torque specs where for the drive shaft nut. The break caliper bus and the bearing hub bolts. The old bearing was wore out and tore up the abs sensor before we noticed it. Car is more quiet than when we bought it used. Was not an easy job either.
Old 10-14-2014, 09:29 PM
rrolleston's Avatar
2007 pacifica touring AWD
Old 10-14-2014, 11:36 PM
cirrus98's Avatar
Drive shaft nut(Hub Nut) : 180 FT/LBS or 244 N.m
Bearing hub bolts: 60 FT/LBS or 81 N.m
And for the caliper, what nuts are you talking about? the 2 that hold the caliper? If so, nice and snug does the job
Old 10-15-2014, 09:23 AM
rrolleston's Avatar
Yes the caliper bolts. Thank you for the info.
mcneesejd
07-29-2009 01:17 PM
Lesley1020
02-20-2009 11:08 PM
donnyohs
11-28-2007 03:17 PM
WYOCHIMNEYSWEEP
09-28-2007 08:37 PM
streetrodder
09-11-2007 09:37 PM
Quick Reply: Torque specs
