Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler PT Cruiser
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 12-29-2008, 07:47 PM
Default 02 PT overheating problem
Ok I have a 02 PT Crusier 2.4 Auto, ok we just recently drove to colorado an as we got into CO my pt started to overheat... when I turn the A/C on, the temp rises in seconds...so i have to drive around without a/c then after about 20-30min's of driving it will overheat if i dont turn the heat on.. so I took it to firestone an they replaced my thermostat, flushed my cooling system, and the fan swith. It continued to overheat, i took it to a dealership an they said to replace the rad cap and I did..which helped quite a but still overheated.. ( Now it should be known that the highest the temp is the second line from the middle) i drove the car back to flordia. an still is doin the same thing.. it has not thrown an codes but iam gonna have a scanner hooked up to see though...I have also checked for oil in my water an water in my oil so Iam stumped as to wat is the problem
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 12-30-2008, 12:18 AM
Default RE: 02 PT overheating problem
Is the cooling fan coming on?
What is the coolant level doing when it is over heating is it still full or did you loose fluid.
Do you see any leaks?
Old 12-30-2008, 02:56 PM
2002 Chrysler Sebring
My Garage
"Now it should be known that the highest the temp is the second line from the middle"
Not sure what you mean by that, but if the temp goes up to a point above the middle a little and stays there, that doesn't mean it's overheating. When they replaced the thermostat they may have put in a slightly hotter stat meaning the car will run a little warmer.
After flushing the system and replacing the stat, the only other thing that comes to mind is a bad radiator hose. The lining can sometimes separate inside the hose and fold over resulting in an obstruction. After 7 years, you might consider replacing them.
__________________
Engineer and current owner of two Sebrings.
Tags
02, ac, car, chrysler, cruiser, dont, heat, heating, overheat, overheating, overheats, problems, pt, turn, why
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
