temperature sensor
Old Jun 4, 2011 | 10:22 AM
larrym's Avatar
Default temperature sensor
I need to check the temp sensor for my radiator fan on my 01 PT Cruiser. Can someone tell me the location of said sensor?
The fan is not comming on and I am trying to troubleshoot the problem.
Also, need the location of the power steering over pressure switch.
Best Regards,
Larrym
Old Jun 4, 2011 | 12:53 PM
if the coolant temp gauge inside is working correctly that means the sensor is also working right because the temp sensor is an input to the pcm and then the pcm tells things what to do. Add power and ground to the fan motors that is what us usually the prob not a temp sensor.
The PS pressure switch is under the car on the rack in pinion next to where the lines go into the rack.
Old Jun 4, 2011 | 07:54 PM
larrym's Avatar
Default PT Cruiser temp. sensor
Thank you for your reply.
Regards,
Larrym
recepomac
Apr 23, 2015 09:32 AM
ranger88den
Jun 6, 2013 02:53 PM
robwill
Mar 15, 2011 03:50 PM
screamingskull
Mar 5, 2009 12:08 AM
tqd4809
Jul 25, 2006 08:41 PM
