2004 Low Idle + oil light issue
Old 07-06-2016, 12:52 AM
SpudlerT+CTouring's Avatar
Default 2004 Low Idle + oil light issue
First I noticed Idle seems low when no accessories are on and even worse when A/C is turned on, Is there a way to adjust this?
I get no codes plus no chk engine light.
looks to be idling about 700 in park (will check with my Autel 539 B scanner to get exact Idle RPM
Also somewhere there is an issue with the Oil light as it comes on internittently and I can see the engine has oil pressure as I can see it running off of top of rockers quite well when looking in through the oil cap.
is there a specific place I shoudl look for a short or do the oil sending units go bad on these?
Old 07-06-2016, 06:30 PM
Idle speed is controlled by the engine computer. There's no adjustment.
Replace the oil pressure switch. You'll probably find it's leaking, but, yes, it's a known problem.
oldcars
10-23-2015 09:53 PM
Dhatz
09-11-2015 01:11 PM
qbasicer
09-25-2012 02:58 PM
OGHBEICA8
06-20-2012 10:44 PM
ijiuini
12-05-2008 03:18 AM
Quick Reply: 2004 Low Idle + oil light issue
