Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler PT Cruiser
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-03-2011, 10:05 AM
Default P0452 NVLD Pressure Switch Sense Circuit Low Input
I Own a 2009 Pt Cruiser2.4l non turbo. Can someone help me fix this Obd2 code.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 09-07-2011, 08:46 AM
Natural Vacuum Leak Detection (NVLD) Pressure Switch may be bad.
The PCM cannot detect leaks or restrictions in the vacuum circuits of vacuum assisted engine control system devices. However, these could cause the PCM to store a MAP sensor diagnostic trouble code and cause a high idle condition.
The Natural Vacuum Leak Detection (NVLD) system is the next generation evaporative leak detection system that will first be used on vehicles equipped with the Next Generation Controller (NGC). This new system replaces the leak detection pump as the method of evaporative system leak detection. This is to detect a leak equivalent to a 0.020" (0.5 mm) hole. This system has the capability to detect holes of this size very dependably.
The basic leak detection theory employed with NVLD is the "Gas Law". This is to say that the pressure in a sealed vessel will change if the temperature of the gas in the vessel changes. The vessel will only see this effect if it is indeed sealed. Even small leaks will allow the pressure in the vessel to come to equilibrium with the ambient pressure. In addition to the detection of very small leaks, this system has the capability of detecting medium as well as large evaporative system leaks.
A vent valve seals the canister vent during engine off conditions. If the vapor system has a leak of less than the failure threshold, the evaporative system will be pulled into a vacuum, either due to the cool down from operating temperature or diurnal ambient temperature cycling. The diurnal effect is considered one of the primary contributors to the leak determination by this diagnostic. When the vacuum in the system exceeds about 1" H2O (0.25 KPA), a vacuum switch closes. The switch closure sends a signal to the NGC. The NGC, via appropriate logic strategies (described below), utilizes the switch signal, or lack thereof, to make a determination of whether a leak is present.
The NVLD device is designed with a normally open vacuum switch, a normally closed solenoid, and a seal, which is actuated by both the solenoid and a diaphragm. The NVLD is located on the atmospheric vent side of the canister. The NVLD assembly may be mounted on top of the canister outlet, or in-line between the canister and atmospheric vent filter. The normally open vacuum switch will close with about 1" H2O (0.25 KPA) vacuum in the evaporative system. The diaphragm actuates the switch. This is above the opening point of the fuel inlet check valve in the fill tube so cap off leaks can be detected. Submerged fill systems must have recirculation lines that do not have the in-line normally closed check valve that protects the system from failed nozzle liquid ingestion, in order to detect cap off conditions.
The normally closed valve in the NVLD is intended to maintain the seal on the evaporative system during the engine off condition. If vacuum in the evaporative system exceeds 3" to 6" H2O (0.75 to 1.5 KPA), the valve will be pulled off the seat, opening the seal. This will protect the system from excessive vacuum as well as allowing sufficient purge flow in the event that the solenoid was to become inoperative.
The solenoid actuates the valve to unseal the canister vent while the engine is running. It also will be used to close the vent during the medium and large leak tests and during the purge flow check. This solenoid requires initial 1.5 amps of current to pull the valve open but after 100 ms. will be duty cycled down to an average of about 150 mA for the remainder of the drive cycle.
Another feature in the device is a diaphragm that will open the seal in the NVLD with pressure in the evaporative system. The device will "blow off" at about 0.5" H2O (0.12 KPA) pressure to permit the venting of vapors during refueling. An added benefit to this is that it will also allow the tank to "breathe" during increasing temperatures, thus limiting the pressure in the tank to this low level. This is beneficial because the induced vacuum during a subsequent declining temperature will achieve the switch closed (pass threshold) sooner than if the tank had to decay from a built up pressure.
The device itself has 3 wires: Switch sense, solenoid driver and ground. The NGC utilizes a high-side driver to energize and duty-cycle the solenoid.
Natural Vacuum Leak Detection (NVLD)/Removal:
1. Disconnect and isolate the negative battery cable.
2. Raise vehicle and support.
3. Disconnect electrical connector from natural vacuum leak detection (NVLD) valve.
4. Remove bolt securing NVLD valve bracket to EVAP canister bracket.
5. Remove hoses from NVLD valve.
6. Remove bolts and NVLD bracket from NVLD valve.
Install:
1. Install NVLD valve to NVLD bracket.
2. Install assembly to EVAP canister bracket.
3. Install hoses and electrical connector to NVLD valve.
4. Lower vehicle.
5. Reconnect negative battery cable.
__________________
Tony Morris
Top Care Specialist
Chrysler Group LLC
I will be returning January 3rd, 2012 and look forward to assisting any questions or concerns you may have once I return. Happy Holidays!
Old 09-07-2011, 04:55 PM
Many thanks ChryslerCares.
Old 09-07-2011, 10:25 PM
TNtech's Avatar
It's an electrical code, not from any sort of EVAP leak. It's mounted on the rear of the gas tank. Look and see if there is any damage to the connector or pigtail. If not, probably replace the NVLD
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
Old 09-08-2011, 07:51 AM
Lemaigre,
Your very welcome for the service manual info. I would suggest taking TNtech's advice to start with. He is a certified expert and very active on the forum so he knows what he's talking about.
Good luck on getting that issue resolved.
Tags
canister, circuit, closed, cruiser, effect, engine, low, map, nvld, open, pressure, pt, removing, sense, switch, valve, vent
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
