Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler PT Cruiser
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 02-13-2009, 03:55 PM
Default PT Cruiser Problem Solved!
Just to let you guys know, I have finally solved the problem with my girlfriends 2002 Cruiser. It had run hot and warped the head. After rebuilding the head and putting things back together, It would not crank unless you un-plugged the cam sensor. Took it to a local dealer. They said the timing was off. They didn't know! Got it back from the dealer and it would crank (As soon as starter engaged) but when it came up to temperature it would cut off. When you tried to start it acted like the timing was off. Keep getting P40 code. Cam sensor circuitry. I had to change BOTH the cam sensor, and the crank sensor. Seems to be running fine now. So, in my opinion, if you change the cam sensor, always replace the crank sensor too. It will save you a lot of headaches!
Thanks for your support and suggestions!!!
Skip
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 02-13-2009, 07:59 PM
2002 Chrysler Sebring
My Garage
Thanks for coming back with the final report.
__________________
Engineer and current owner of two Sebrings.
Tags
2002, cam, change, chrysler, code, crank, cruiser, cut, issues, problem, pt, replace, sensor, sensors, troubleshoot
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
