Look on the bottom of the relay you will see numdered pins...86...87 etc. You may need a magnifying glass.
84 Yellow-Power from Ignition switch. (Hot with ignition on)
82 Tan - PCM control. This is a ground circuit the PCM closes. If your PCM is bad you can actually run this to permanent ground BUT, it bypasses your security and neutral safety so I would not normally advise it.
85 Red - Battery power (always hot)
81 Brown - This is your Solenoid wire to the starter.
83....is nothing just 81 at rest.
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
