0406: EGR Position Sensor Volts Too High. EGR position sensor input above the acceptable voltage range.
1289: Manifold Tune Valve Solenoid Circuit An open or shorted condition detected in the manifold tuning valve solenoid control circuit.
Do these 2 codes coincide with each other?
Is my EGR valve bad?
Where is the valve located?
I know that this is not the original engine in the car. I was told this was a rebuilt crate motor. The codes were cleared twice, and keep coming back with the same 2 as mentioned above. I have read online that some engines have an EGR and some don't. There are no unplugged connectors from what I can see.
Thank you in advance for your time and answers.
Yes and No....They could be related to each other...But doubtful...
Chrysler EGR valves are ...In a Word...ATROCIOUS..... It is not uncommon for an EGR solenoid to crap out... MTV....Same deal.....
MTV is now replaced with the upper intake plenum......and as for egr...Look for the metal tube going into the upper plenum...and follow the tube down towards the manifold....Egr willl meet up with the left and right side tubes.
__________________ Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Have to remove it????....No , not really, but it does make life easier.
Well Duh , Djinn.......It might help if the guy knew what pins were what......
Sorry about that...
CAV CIRCUIT FUNCTION
1 K34 20DB/LG EGR SIGNAL
2 F856 20YL/PK 5 VOLT SUPPLY
3 K900 20DB/DG SENSOR GROUND
4 Z904 20BK/BR GROUND
5 - -
6 K35 20DB/VT EGR SOL CONTROL
