Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 07-22-2011, 03:58 PM
Default '02 2.7L Belt Tensioner
Hello,
I'd like to know for those of you who've changed the AC/Alt belt on the 2.7 whether the belt will simply slip off the tensioner with little effort or whether you need to use some kind of impliment to force the belt with the tensioner in full slack position. I recently discovered a leak near the thermostat housing and replaced the lower hose, thermostat and gasket. I needed to remove the belt in the process. The belt that was originally on the car doesn't want to go back on the car, I place it on the crank, Alt and AC compresser and i'm missing a good 3/4 of an inch of room to get it on the tensioner. Do I have the wrong belt?
-Andrew
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 07-24-2011, 05:18 PM
2002 Chrysler Sebring
My Garage
The belt tensioner has a pivot bolt and a locking bolt. You must loosen both to free up the tensioner and allow it to move. Then you can pivot the tensioner, install the new belt and use a breaker bar in the square hole to re-apply tension on the new belt. While holding the tension, tighten the lock bolt and pivot bolt.
Tags
01, 02, 27, 27l, belt, chrysler, dodge, leaking, magnum, release, releasing, sebring, specifications, tension, tensioner, thermostat
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
