Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-02-2011, 08:25 PM
Default 02 sebring,oil light flicker
Hello, have an o2 sebring with the 2.7...the oil light flickers at idle.. so i pulled the sender.. checked the psi and had 25 psi hot.. had 70 psi at 3k rpm.. replaced the switch and the light still flickers.. not all the time tho.. and the hyd tensioner knocks.. we change it and it was a lot quiter.. now its a light tick sound.. anyone else have this problem with thier 02??
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 09-02-2011, 10:48 PM
2002 Chrysler Sebring
My Garage
Minimum specified oil pressure at idle for this engine is 5 psi. At 3000 RPM, the oil pressure should be between 45 and 105 psi.
You might want to pull that sender out again and make sure the passage leading to it is clean. If the engine is sludged up the pressure may be good but if the passages are clogged, you won't be getting oil where you need it.
Are you using the proper weight oil?
Tags
02, 27, check, chrysler, fix, flicker, flickering, flickers, idle, lamp, light, oil, psi, sebring, shoul
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
