'02 XL 2.7L - The Intake Manifold/Plenum
Old 08-04-2013, 10:01 AM
jgstudios`'s Avatar
Default '02 XL 2.7L - The Intake Manifold/Plenum
I'm trying to learn more about this car, and I have some questions about the intake manifold. In my case, I've removed it from the engine so now I can examine it thuroughly. I notice there's oil in it, not alot, but I can see there is a film of it along the passages, and if I tip it, some oil will drip out. Is that normal? If not, can someone explain what might be wrong. If there are cracks in it, besides visual inspection, is there a way to find cracks? should I remove all the sensors and clean it out? If so, what should I use to clean it?
Old 08-04-2013, 04:20 PM
PCV valve is more then likely faulty and use brake clean to clean it out
Old 08-06-2013, 09:25 PM
jgstudios`'s Avatar
Very good. I'll assume I need to remove the sensors as well. Thanks for your response. JG
fakegreasemonkey
09-12-2016 02:44 PM
ssmehta007
11-22-2014 08:53 PM
syxx20603
01-25-2010 01:54 PM
denn3.0v6
07-04-2009 01:53 PM
Quick Reply: '02 XL 2.7L - The Intake Manifold/Plenum
