Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 02-15-2012, 11:20 PM
Default '05 2.7L Sebring Radiator fans always ON
The radiator fans turn on when the engine starts and do not turn off. No problem getting heat, but the temp gauge tops out at 1/4, used to be 1/2.
The issue seemed to start after I replaced the air bleeder housing (with new temp sensor), so could the sensor be off? But why would the fans turn on if the engine appears to not warm up enough?
Maybe the fan relays are bad?
Just replaced the thermostat, no change.
Thanks for any assistance!
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 02-16-2012, 08:18 AM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
if the issue was not there b4 u replaced an item logical conclusion
the issue seemed to start after I replaced the air bleeder housing (with new temp sensor),
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 02-16-2012, 10:40 PM
If anything about this car was logical the thermostat would not be where it is.
Does the temp sensor in the bleeder housing only control the gauge, or does it also control the radiator fans?
If the fan relay is bad, could it cause the fans to always be ON?
Since the fans run constantly, is this causing the temp to not reach normal?
In short, what possibilities would cause this to happen?
Old 02-16-2012, 11:22 PM
2002 Chrysler Sebring
My Garage
You're right, this doesn't make a great deal of sense. There is only one source of information regarding coolant temperature, and that is the sensor you replaced. Its signal is read by the engine computer and is one of the factors controlling the fans, A/C operation and automatic transmission fluid temperature being other factors. The same signal is processed by the engine computer and forwarded to the body computer to control the readout of the temperature gauge. So you'd think that if the sensor was reading high enough to keep the fans on, the gauge would also read high.
All that being said though, if there's a failure somewhere along the line, the default is to turn the fans on to provide cooling in case of doubt.
So if the fans are running all the time, the chances are the computer is not happy with the signal it's getting from somewhere and is running the fans "just in case".
This might show up if you could hook the car up to the proper diagnostic equipment.
I doubt that the fans are making the car run cooler than it should. The thermostat should control that.
There's probably a pretty good chance that replacing the temperature sensing unit would fix the problem, especially since installing it seems to have precipitated the problem.
Could the fan relays be stuck on? Maybe. Not real likely, but not impossible. There are two fan relays, one for each fan, so it's not likely that both would fail in the same manner at the same time.
Tags
14, 2002, 27, allowing, chrysler, diagnose, fan, fans, guage, rad, radiator, sebring, temperature, turning, warm, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
