Originally Posted by teddysmith1952
Ok. Your original post indicated you just had the rears done, thus the confusion. Having to "pump" the brake pedal a couple of times to get it up and firm indicates to me an issue in the brake hydraulic (fluid) system. Possible caliper, air in the system...etc. Definitely no adjustments can be made to the brakes. Have you noticed any brake fluid on the ground?
i do not notice any leaking fluid but i wonder if the mechanic opened the bleeders when compressing the calipers to install new pads and at this point maybe trapped some air in there.
i will bleed the system and see if that helps, thanks for the reply's.
