07 sebring surging
Old 04-09-2007, 03:39 PM
markshop's Avatar
Default 07 sebring surging
Yes an 07 sebring with only 500 miles is surging.Anywherebetween 40 to 60mph it surges 200rpm when using the accelerator.It stops surging when you set cruise. The idle is steady. Any ideas? I thought maybe the accelerator peddle sensor. Oh well it does go in in a couple days. No check engine light.
Old 04-09-2007, 08:32 PM
Default RE: 07 sebring surging
If you are talking about TCC engagement, yes mine did that as well. Many of the newer Chryslers I have owned do this. They started a TCC break in period that would last about 500 miles a few years back. I believe they discontinued it, but recently I think it has been reinstated. It is supposed to give the new converter time to "break in" for the lockup clutch.
Inside the torque converter the clutch is bonded with glue. They tend to rip the glue backing apart after many thousands of miles. In an effort to ease the strain on the clutch in the beginning, the TCC is not fully applied. You should notice it disappearing pretty soon. Everytime the computer is reset it "could" reset the TCC break in period though.
Again, I am stating facts from earlier models and I am not 100% positive that this is your issue. Hope this helps.
Old 04-09-2007, 08:40 PM
there is a flash it might be for u read this and see I dont know unless i have a vin number
is bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-002-07, DATED
JANUARY 31, 2007, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL
REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE A PART
NUMBER CORRECTION.
THE StarSCANĀ® FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM
THE INTERNET.
StarSCANĀ® SOFTWARE LEVEL MUST BE AT RELEASE 7.03 OR HIGHER.
StarMOBILE STANDALONE DOES NOT SUPPORT THIS SERVICE ACTION.
SUBJECT:
Flash: Torque Converter Shudder / Shift Quality Improvements / DTC P0732
OVERVIEW:
This bulletin involves reprogramming the Powertrain Control Module (PCM) with new
software and replacing the torque converter as required.
MODELS:
2007 (CS) Pacifica
2007 (DR) Ram 1500
2007 (HB) Durango
2007 (JK) Wrangler
2007 (JS) Sebring
2007 (KA) Nitro
2007 (KJ) Liberty
2007 (LE) 300C/300 Touring (International Markets)
2007 (LX) 300/Magnum/Charger
2007 (ND) Dakota
NOTE: This bulletin applies to CS/DR/HB/JK/JS/KA/KJ/LE/LX models built with a
41TE, 42RLE, or 62TE automatic transmission (Sales Codes DFF, DGV, or
DG2). built on or before December 15, 2006 (MDH1215XX) and ND models
with 42RLE built on or before January 2, 2007 (MDH0102XX).
NUMBER: 21-002-07 REV. A
GROUP: Transmission
DATE: February 10, 2007
NOTE: This bulletin DOES NOT apply to JS models with a 2.4L engine.
SYMPTOM/CONDITION:
The vehicle operator may experience one or more of the following symptoms:
1. Transmission Shudder - 42RLE All, 41TE CS/JS, 62TE CS/JS
a. This condition can only occur after the vehicle has been driven and the torque
convertor is past the break in period. Torque Converter break in can be confirmed
with the StarSCANĀ®.
b. If experienced, the shudder may occur when the transmission temperature is
between 38Ā° C and 54Ā° C (100Ā° F and 130Ā° F) during steady state driving with the
torque convertor in partial lock (EMCC) operation. The shudder feels like the vehicle
is being driven over rumble strips.
2. Torque Converter Pull In Bump - 41TE JS, 62TE CS/JS
a. This condition can occur due to abrupt torque converter clutch engagement during
EMCC initialization.
3. DTC P0732 - Gear Ratio Error in 2nd Gear - 62TE CS
a. The MIL may or may not be lit (2 trip fault).
b. Limp In will occur when this fault is set.
c. This is an intermittent condition and cannot be duplicated. If the fault can be
duplicated, other conditions exist and further investigation will be required.
4. Shift Quality Improvements - 62TE CS
a. Rapid Decel Coastdown Stumble.
b. Low Speed 3-2 Kickdown Harshness.
c. 4-5 and/or 5-6 upshift flare bump.
DIAGNOSIS:
Using a Scan Tool (StarSCANĀ®) with the appropriate
Old 04-09-2007, 09:57 PM
markshop's Avatar
No i dont think it has anything to do with the torque converter. This happens after you are in high gear and converter is locked. Engine will surge by 200 rpms on level road.The tach will climb 200rpms then right away drop 200rpms and goes on continuisly until you press further on pedal. It stops if you set the cruise.
Old 04-10-2007, 01:54 AM
the converter is high gear my friend its basicly a 1:1 gear ratio with lockup. It will go in and out based off road and pedal condition.
Old 04-10-2007, 09:43 AM
markshop's Avatar
Again this happens after the converter locks up and the road is level and you hold the pedel completlysteady. I dont know how to explain it any clearer. The engine revs up and down by 200rpm very quickly. Almost like you are pumping the accelerator.Cannot feel any shifting at all. But if you set the cruise its fine. Still thinking the apps.
Old 04-10-2007, 12:25 PM
if it was the apps u would get a code there is 2 apps in the throtle body and 2 in the pedal
if one set was bad then the other would see the miss match in volts and set a code and go into limp in as far as the tranny. The tsb above should take care of the tranny surging with an updated software package on TCC.
Old 04-10-2007, 02:24 PM
markshop's Avatar
Ok why would the surging stop if you quickly set the cruise when its surging? Seems it only does this when your foot is on the pedal.
Here is the vin # 1C3LC56KX7N509329
Old 04-12-2007, 09:15 PM
The 200 rpm up/down was exactly what mine was doing. When I used the cruise it STILL did it though. This is the TCC cycling. This is not the first time that MOPAR has had this issue with it's converters/programming. Not a big thing if you get it corrected.
I am planning to take mine in shortly to get the flash, even though it stopped doing it for the last 1000 or so miles.
Thanks for the TSB. Kinda figured they might be putting that one out.
Old 04-13-2007, 10:03 AM
markshop's Avatar
Update!!!
The dealer did reflash the pcm and it does seem to have fixed the surging. Thanks for all the help Chrysler tech and blue 07. Sorry for under estimating you guys. Thank again. Till more problems.
msg123456
05-28-2013 02:44 PM
aocano123
Cirrus & Breeze
06-25-2010 01:31 PM
horsecrazd311
05-22-2009 01:05 PM
97K15004WD
11
03-17-2008 09:08 AM
greeniebfd
12-01-2005 05:10 PM
Quick Reply: 07 sebring surging
