2000 Convertible Will not Start Can't be Jumped
I have a 2000 Convertible and everything was working fine. I had not driven it for a while and I got in it and it would not crank at all - acted like the battery was dead. I hooked the battery to a programmed charger and after several hours and the charger indicated that the battery was charged. Still would not crank at all. I hooked it up to my truck's battery and it appeared there was a short in the system as the jumper cables got hot almost immediately and it still would not crank.
I have the manual for this vehicle and I first thought there might be a problem with the voltage regulator and quickly discovered that it did not have one. The manual says that this function is now handled by the power distribution center. It looks like replacing this is an easy job, but I can't find the part and one U-Tube video showing how to replace the part said it was almost $1,000.00.
What could be wrong?
The vehicle had been sitting less than a week. The battery was replaced about a year ago. The vehicle I tried to jump it with was a 2003 Dodge Ram diesel, which as a total aside, still has its original batteries and they work like a champ. Then I made the attachment I got more "sparks" than I normally get when the cables are completely hooked up. That concerned me and I quickly tried to start the Sebring and, nothing. When I disconnected the jumper cables, the were already hot and the insulation started to melt. The truck was unaffected - fortunately.
By the way, thanks for the quick response.
Start checking fuses...all of them. Also see if the fusible link between the starter and alternator is melted.
Chrysler Forum Editor
11-01-2013 04:18 PM
zduncan1
07-05-2012 04:31 PM
musicfreak2195
10-08-2008 08:55 AM
