Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
Search
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 02-12-2006, 11:54 PM
Default 2001 LXI high speed blower works only
What are the chances that this problem is the blower resistor? Has anyone replaced it before? Where is it located?
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 02-12-2006, 11:55 PM
Default RE: 2001 LXI high speed blower works only
Does the resistor sit inside the blower motor itself or is it some other place?
Old 12-12-2011, 02:15 PM
2002 Chrysler Sebring
Its behind the glove box. I had this same problem and replace the blower motor resister with one from a PT Cruiser and have had no problems since, that was four years ago.
Old 07-24-2012, 09:53 PM
acl acl is offline
I had the same problem on a 2001 T&C LXI. The blower motor would always run on high and we could not shut it off. I replaced the blower motor resister about 6 months ago. The same problem has re-occurred. Since it apprears that the blower motor resister has failed again. Does this mean that the blower is bad (along with the resister)? Please respond/advise.
Old 07-24-2012, 10:55 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
more then likely yes
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 08-27-2012, 11:56 PM
Default Maybe a compatibility issue
My a/c would only work on high. Replaced the a/c heater control panel (X2). No good. Researched a little and changed the blower control reisistor. On my 2002 Sebring it's behind the glovebox, under the dash by the blower. Disconnect the electric and there are two (2) screws holding in the resistor. Now after changing the resistor it worked fine for awhile then started blowing air through the defrost, then straight out, then defrost again . I got my resistor from a junk yard and I think it be wise to make sure the resistor is compatible with your vehicle and the vehicle you get the resistor from. The new resistor looked completely different than the one replaced. I think there was a TSB on this resistor. I am sure there is a range there but check to be sure. Thanks.
__________________
Kennyk
Osiyo my friend
Old 08-31-2012, 09:31 AM
I purchased control resistor from the dealer (about $35.00), was told that original resistors were manufactured in Hungary, newer ones from Mexico. New resistor is a little bigger than original and looks a little different, so I used a Dremel tool to enlarge opening. Works fine now.
Tags
2001, blower, blowser, chrysler, fan, high, lxi, motor, sebring, speed, work, works
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
Internet Brands, Inc.
Emails Backup
