2002 2.7L Misfire
2002 2.7L Misfire
Hi, My 2002 2.7 Litre Sebring has a bad misfire. Codes po300 and po303. changed all plugs and coil pack on number 3 cylinder.mechanic also checked injectors, says they are fine. No oil dripping anywhere in engine or ground, clean oil. Lost from here, any help is appreciated.
Thank-you
Ct, yes 'mechanic said both these procedures were done and both ruled out. One code today on reader.... P0303. Still has a serious misfire'
Ct, thanks for your input. Local mechanic did a compression test and hooked up diagnostic equipment. No compression in cylinder #3. Says stuck or bent valve, as this car did not over heat. Would you agree with the mechanic that this is not worth pursuing? Also, are there any additives or other quick fixes that are worth a try that may free up this valve. Thanks again, much appreciated.
Why is it, any ideas would be appreciated, that when I start the car its rough as hell with it running on 5 cylinders, Ill red line it 2 or 3 times in low gear and the car will run PERFECT until its shut off and started again. Over to you you Mr,CT.
