Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-18-2011, 06:10 AM
Default 2002 sebring conv jxi no spark help needed
2002 sebring conv jxi 2,7 v6 I just replaced the water pump and resurfaced the front head. Before this work the car would not start and had milk for oil. The front head had obvious blown gasket so the above repair was necessary as well the water pump was gone. I painstakingly set the timing and am positive the timing is dead nuts. The car now has from 120 to 150 psi all around but no start! It seems that there is a random spark, when I hook up a blinker to a plug an crank I get a random blink and sometimes no blink at all but if I do get one it is just one blink then nothing while cranking it over . I can tell the spark is jumping around sporadically by the unsteady turn over and it seems to want to start for a second but it doesnt.
I checked for reference voltage at the cam crank and tps sensors and am receiving 4.9ish so ??? the asd and fuel relay are powering up for a split sec at key on so??? Oh and yes the crank and cam sensors are brand new. I don't have an oscilloscope so reading the pulse from the sensors is going to be hard. I haven't run a fuel pressure test because the spark is basically nonexistent I am thinking new PCM?? please help me if you have any Idea as to what direction my trouble shooting should go I really dont want to tear it down to see the timing is in fact correct and is not the source of my woes.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 09-19-2011, 10:19 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
unplug the cam sensor and hold the key over for 10 seconds or more see if it will start up.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 09-20-2011, 03:50 PM
Default starts with out cam sensor
Yeah I t starts fine and runs smooth with out the cam sensor plugged in. Do you think I skipped a tooth cranking it over the first time?? I hope not but I can check it out. I have been told it is common on the 2.7 to skip a tooth or two after timing chain service? Thanks for the advice. P.S. I did wire wheel off some rust from the timing gear and tone wheel for the cam sensor , do you think I magnetized it? would that pose a problem?
Old 09-20-2011, 09:15 PM
if u were off a tooth it would not run at all if u did anything u did it to that cam tone wheel.
__________________
KKeller608@aol.com
Tags
02, 2000, 2002, 27, chrysler, crank, fuel, give, jxi, key, sebring, sedan, skip, spark, timing, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
