Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 07-13-2011, 02:42 PM
2002 Chrysler Sebring
Default 2002 Sebring LX - Radiator Drain Plug
Hi there, as dumb as this sounds....
How the heck do you get at the drain cock?
If I was to go to a garage to flush my rad it will cost $170!
Well I'd rather do it myself for the cost of the coolant.
Only problem is getting to the drain cock...
Anyone have any tips?
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 07-31-2011, 12:53 PM
I'm having the same problem with the drain cock....no idea.
I've read to be sure to have a backup plug because they break easy
Old 07-31-2011, 08:21 PM
My Garage
In the past, I have used these:
Prestone® Flush N Fill Kit | Print View | Products | Prestone®
If you can get to a heater hose, you can use this to flush the whole system. Be careful, though: City water pressure can be as high as 90 psi, compared to the 16 psi your water pump seals were designed for. So flush the system slowly, just crack the hose valve enough to get the water flowing gently through the overflow of the kit.
When you are finished flushing, you add coolant and push the water out until coolant starts coming out.
Don't touch the bleed screw on a 2.7L engine to bleed the air. It's a metal fitting in a plastic housing and the whole fitting can spin in the plastic when you put a wrench on the screw. Just let the system bleed itself through a couple of warm-up and cool-down cycles and add coolant as necessary.
Old 08-20-2011, 11:51 PM
helo735's Avatar
lol you said "cock"
Tags
2002, chrysler, chryslers, convertable, drain, draincock, flush, location, lxi, plug, radiator, removing, seabring, sebring, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
