what does not come on? and what is high side 150 both?
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep KKeller608@aol.com http://kevinsmobilerepair.com
ok first of all if your gauges are pre 134 then they wont hook up r12 and 134 use different size connectors and u should have about 100 psi on both sides when the compressor is not on and when running about 35 to 250.
when it wont work check for the power and ground at the compressor connector see which u are missing.
__________________
check your fuses and powers to the fuses one is more then likely blown
__________________
